Component: Zigbee (EB051, XBEE) (XBEE) (Wireless)
Author Matrix Ltd.
Version 1.5
Category Wireless
Zigbee (EB051, XBEE) component
Zigbee component designed to work with the XBEE range of modules from Digi. Provides a very simple interface to allow Zigbee mesh networks and communications. Also available in the form of the EB051 Zigbee E-block. Can also be used with Zigbee MIAC Addon module
Please click here to download the component source project: FC_Comp_Source_Zigbee.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Zigbee.fcfx
ConnectFromLibrary
ConnectFromLibrary
Attempts to connect the data channel to a known device on the network.
- BYTE Mode
- BYTE Device
ConnectToAddress
ConnectToAddress
Attempts to connect the data channel to a specific device address on the network.
- STRING Address
ConnectToAll
ConnectToAll
Attempts to connect the data channel to all devices on the network.
ConnectToCoordinator
Attempts to connect the data channel to the network coordinator node.
ConnectToName
ConnectToName
Attempts to connect the data channel to a named device on the network.
- STRING Name
EnterCommandMode
EnterCommandMode
Moves from data mode into command mode by sending the special characters
ExitCommandMode
ExitCommandMode
Returns from command mode to allow data to be sent and received
GetATResponse
GetATResponse
Waits for a response from the Zigbee module. If the Logging parameter is set then the response is stored in memory allowing the software to read the reply.
- BYTE Logging
GetSignalLevel
GetSignalLevel
Returns the signal strength of the last signal received
InitNetwork
InitNetwork
Initialises the Zigbee module and attempts to setup or join the network
MIAC_Module_GetData
MIAC_Module_GetData
- BYTE Index
MIAC_Module_Message
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_PushData
- BYTE Data
NodeConfigureSleep
NodeConfigureSleep
Sets the Zigbee device sleep mode (only applicable for end node type devices) ,
- BYTE Mode
1=Hibernate, 2=Doze, 4=Cyclic Sleep, 5=Cyclic Doze
- UINT Timeout
Time to sleep in milli seconds (ms)
NodeWake
NodeWake
Wakes up the local Zigbee module from sleep mode.
ReadATResponse
ReadATResponse
Reads a single byte from the received AT command response.
- BYTE idx
Specified the byte index in the buffer. Range 0-15
ReadAddressFromBuffer
Reads a byte from a 16-bit Zigbee device address
- BYTE Device
- BYTE Idx
ReadNameFromBuffer
ReadNameFromBuffer
Returns a byte from the 8-Byte name
- BYTE Device
The Device name to collect. Range: 0-7
- BYTE Idx
The index position of the name. Range: 0-7
ReceiveChar
ReceiveChar
Attempt to receive a byte from the Zigbee module.
- BYTE nTimeout
RestartNetwork
RestartNetwork
Attempts to restart the network
ScanBuffer
ScanBuffer
Returns a binary list of matched identifier names
- STRING Compare_Str
- BYTE Length
ScanNetwork
ScanNetwork
Scans the local network for devices and stores into a local device array. Mode = 0 store device names, mode = 1 store device addresses. Returns the number of devices found.
- BYTE Mode
SendATCommand
SendATCommand
Transmits a string of values to the Zigbee module.
- STRING Command
Transmits a command to the Zigbee module followed by a carriage return
SendChar
SendChar
Transmits a byte value to the Zigbee module.
- BYTE Byte
Data byte to transmit. Range 0-255
StoreParams
StoreParams
Stores the current register set into the Zigbee module's non volatile memory
Device Name
String of characters used to allow the Zigbee node to use the name addressing mode of operation. Can be left blank if name addressing is not being used.
Zigbee Mode
Specifies the functionality of the Zigbee node. Coordinator - Must be used with a Coordinator Zigbee E-Block EB051C, Responsible for starting the network and assigning addresses. Router - Must be used with a Router / End Node E-Block EB051R, Responsible for forwarding / repeating packets on the network. End Device - Must be used with a Router / End Node E-Block EB051R, Capable of low power operation.
Auto ID
Automatically generate a PAN ID
PAN ID
Assigns a Personal Area Network Identifier code to the Zigbee node. Random / Search - Scans the local area for Zigbee PAN networks and joins the existing network, otherwise a random value is chosen. Preset - Assigns a preset PAN ID to the Zigbee node, Must be between 0x0 and 0x3FFF.
Node Join Time
Length of time in seconds where nodes are allowed to join the network. Infinte - Nodes are always allowed to join the network. Preset - Nodes are only allowed to join the network for a specific amount of time. Note: Join time not available for End Device nodes.
Max Hops
Specifies the maximum number of retransmits for a Broadcast transmission.
Sleep Buffer Time
Length of time to buffer packets for sleeping or powered down nodes. This value must be consistent throughout the Zigbee network. Default - Assigns the maximum buffer time of 28 seconds. Preset - Allows for a custom sleep time of 0.32 - 28 seconds.
TX
RX
Baud Options
Use Flow Control
RTS
Pin to be used for Request To Send handshake function Output from target micro to inform remote device we are ready to receive data. Low = Ready to receive data High = Not ready to receive data
CTS
Pin to be used for Clear To Send handshake function. Input to target micro to inform when the remote device is ready to transmit data. Low = Ready to transmit data High = Not ready to transmit data
Sleep Pin
Zigbee Sleep Control Pin
Scan Channels
0x0B
Determines if channel will be scanned
0x0C
0x0D
0x0E
0x0F
0x10
0x11
0x12
0x13
0x14
0x15
0x16
0x17
0x18
0x19
0x1A
Scan Duration
Configures the length of time to scan each channel for network activity. The overall time for the entire channel scan is shown as channel scan time.
Total Scan Time (ms)
The total amount of time that it will take to perform a complete RF channel scan based on the selected scan channels and duration.
Console Columns
Data Source
