Component: DAC (Internal) (Analog Output)
Revision as of 16:45, 25 June 2026 by Wiki bot (talk | contribs)
Version 2.0
Category Analog Output
DAC (Internal) component
Provides access to the onboard digital to analog converter (DAC) peripheral allowing for simple analogue output. Often the DAC output will be very low current and will need amplification using external circuitry to drive anything useful.
Disable
Fc9-comp-macro.png Disable
Disables the DAC output.
Enable
Fc9-comp-macro.png Enable
Enables the DAC Output.
GetList
Fc9-comp-macro.png GetList
Fc9-string-icon.png - STRING Name
GetValue
Fc9-comp-macro.png GetValue
Gets the Name property value
The name of the property
SetOutput
Fc9-comp-macro.png SetOutput
Sets the output voltage of the DAC
Fc9-u16-icon.png - UINT DAC_Value
The value to output to the DAC
SetValue
Fc9-comp-macro.png SetValue
Sets the Value for the named property
Name of property to update
Fc9-string-icon.png - STRING Value
The new value for the property
Fc9-type-16-icon.png Channel
DAC Channel number
Fc9-type-5-icon.png DAC Output Pin
DAC Output Pin
Fc9-type-7-icon.png Alt Pin
Fc9-type-16-icon.png Vref Option
Fc9-type-15-icon.png Vref Voltage
Fc9-type-14-icon.png Control Bits
Fc9-type-10-icon.png Resolution
Fc9-type-15-icon.png Voltage Resolution
Fc9-conn-icon.png Simulation
Please click here to download the component source project: FC_Comp_Source_DAC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC.fcfx
