Viewing Code Output
Revision as of 08:56, 2 May 2023 by MartinW (talk | contribs)
Flowcode allows users to view the C code produced by Flowcode.
To view the code select Build > View C Code
Opens the C Code up in the File Viewer specified in the Compiler options.
Using an External File Viewer
The File viewer settings are contained within the Compiler Options
To view the File Viewer Settings (Build > Compiler Options... > File Viewer tab).
Edit the File Viewer options to point to the desired editor, and set any command line parameters required for the viewer.
Select Use external program to view source files
