| Author
MatrixTSL
| Version
2.0
| Category
Graphical Library
Display Manager component
The component can create the following objects.
- Object_Hidden - 0 - A hidden area with no graphics.
- Object_Rectangle - 1 - A simple rectangular box.
- Object_Line - 2 - A simple straight line.
- Object_Ellipse - 3 - A simple ellipse or circle.
- Object_EllipseFilled - 4 - A filled ellipse or circle.
- Object_RectangeFilled - 5 - A filled rectangular box.
The component can also create the following interactive buttons and sliders.
- Widget_Hidden - 0 - A hidden area with no graphics.
- Widget_Rectangle - 1 - A rectangular box with a shadow.
- Widget_RoundedRectangle - 2 - A rounded rectangular box with a shadow.
- Widget_Ellipse - 3 - A simple ellipse or circle with a shadow.
- Widget_VSlider - 4 - A vertical slider with a square thumb.
- Widget_HSlider - 5 - A horizontal slider with a square thumb.
- Widget_VSlider_Round - 6 - A vertical slider with a round thumb.
- Widget_HSlider_Round - 7 - A horizontal slider with a round thumb.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Object_Rectangle or DisplayManager1::Button_VSlider
An example showing how to use the display manager with a GLCd and a touch interface to create a full HMI.
Display Manager Demo
CheckForTouch
CheckForTouch
| Uses the X and Y coordinates from a touch sensor to check for button presses. Returns 0 for no buttons pressed. Returns 1 for a valid button press. The ID of the pressed item can be found by calling GetButtonID macro. Any touched slider buttons will automatically move their thumb and value to the touch position.
- UINT
X
- UINT
Y
- BOOL
ClearAll
ClearAll
| Removes all objects and buttons from memory. Also clears the screen if required.
- BOOL
ClearScreen
| 0=Don't clear the screen, 1=Clear the screen
CreateButton
CreateButton
| Define an interactive button or slider. Returns the Button ID.
- BYTE
ButtonType
| 0=ButtonHidden, 1=ButtonRect, 2=ButtonRoundedRect, 3=ButtonEllipse, 4=VSlider, 5=HSlider, 6=VSliderRound, 7=HSliderRound
- UINT
X
| X Pixel Coordinate
- UINT
Y
| Y Pixel Coordinate
- UINT
Width
| Pixel Width or X Radius
- UINT
Height
| Pixel Height or Y Radius
- BYTE
Theme
| Theme index to use to draw the button
- BOOL
DrawButton
| 0=Do not draw button yet, 1=Draw button now
- UINT
CreateObject
CreateObject
| Define a none touchable graphical object. Returns the Object ID.
- BYTE
ObjectType
| 0=Hidden, 1=Rect, 2=Line, 3=Ellipse, 4=FilledEllipse, 5=FilledRect
- UINT
X
| X Pixel Coordinate
- UINT
Y
| Y Pixel Coordinate
- UINT
Width
- UINT
Height
- BYTE
Theme
| Theme index to use to draw the object
- BOOL
DrawObject
| 0=Do not draw object yet, 1=Draw object now
- UINT
DrawAll
DrawAll
| Redraws all of the defined Objects and Buttons. Doesn't draw text, this is done using the SetText macro.
DrawItem
DrawItem
| Draws a single object or button onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro.
- UINT
ID
| Unique ID of the Object or Button
GetLastTouchID
GetLastTouchID
| Gets the ID of the last button that returned a valid press via the CheckForTouch macro. Returns -1 for valid touch recorded.
- INT
GetSliderValue
GetSliderValue
| Reads the value of one of the sliders ranging between 0 and 1.
- UINT
ButtonID
- FLOAT
| Initialises the object and button control variables and sets up the default themes.
ModifyPosition
ModifyPosition
| Moves an existing object or button to absolute coordinates on the screen.
- UINT
ID
| Unique ID of the object or button
- INT
X
- INT
Y
- BOOL
Relative
| 0=Absolute Positioning, 1=Relative Positioning
ModifyScale
ModifyScale
| Changes the width and height of the selected Object or Button.
- UINT
ID
- UINT
Width
- UINT
Height
ModifyTheme
ModifyTheme
| Changes the theme index of the selected Object or Button.
- UINT
ID
- BYTE
Theme
| Theme index of the button or object
NoTouch
NoTouch
| Called when no touch is present, Allows the repeat rate counter to be cleared allowing for better responses to fast touches.
OverrideButtonTheme
OverrideButtonTheme
| Overrides the colour of a button theme, used by the draw button macro.
- BYTE
ThemeIndex
| Index of the object colour theme
- BYTE
FG_R
| Foreground colour channel value
- BYTE
FG_G
- BYTE
FG_B
- BYTE
BG_R
| Background colour channel value
- BYTE
BG_G
- BYTE
BG_B
- BYTE
HL_R
| Highlight colour channel value
- BYTE
HL_G
- BYTE
HL_B
- BYTE
LL_R
| Lowlight colour channel value
- BYTE
LL_G
- BYTE
LL_B
OverrideObjectTheme
OverrideObjectTheme
| Overrides the colour of an object theme, used by the draw object macro.
- BYTE
ThemeIndex
- BYTE
FG_R
- BYTE
FG_G
- BYTE
FG_B
- BYTE
BG_R
- BYTE
BG_G
- BYTE
BG_B
SetSliderValue
SetSliderValue
| Sets the value of one of the sliders and optionally redraws the slider to reflect the value change.
- UINT
ButtonID
- FLOAT
Value
| Range: 0 to 1
- BOOL
RedrawSlider
| 0=Do not redraw, 1=Redraw
SetText
SetText
| Draws a single line of text onto an object or button location. Useful for labelling buttons or having name, value statistics. Drawn using the object themes.
- UINT
ID
| Unique identifier of object or button.
- STRING
Text
- BYTE
Font
- BYTE
HAlignment
| 0=Left, 1=Center, 2=Right
- BYTE
VAlignment
| 0=Top, 1=Middle, 2=Bottom
- BYTE
Theme
| Object theme index to control the colour of the text
- BOOL
Transparent
| 0=Background Colour Drawn, 1=Don't Draw Background Colour
LinkTo
Ram Usage Bytes
| The calculated number of bytes of RAM required by the display manager.
Text Align Offset
| Number of pixels to move away from an edge when calling SetText
Objects
Max Objects
| The total number of primitive objects allowed on the screen at once. Sets the size of the RAM buffers used to track the various screen elements. Each object requires 10 bytes of RAM to stores things like size, location and type.
Object Theme Count
| Sets the number of themes available when drawing primitive objects. Each object theme requires 6 bytes of RAM to store the colour channels.
Theme 0
Foreground
| Foreground colour of the theme
Background
| Background colour of the theme
Theme 1
Foreground
Background
Buttons
Max Buttons
| The total number of touchable interactibe objects allowed on the screen at once e.g. buttons and sliders. Sets the size of the RAM buffers used to track the various screen elements Each button requires 18 bytes of RAM to stores things like size, location, value and type.
Touch Repeat Rate
| Sets the period for touch repeats in terms of calls of the CheckForTouch macro. Buttons will only register a repeat touch after x calls if continually held down. Sliders will always register a touch. The touch count can be cleared using the NoTouch macro if no touch is detected.
Slider Thumb Width
| Number of pixels wide to make a slider thumb marker,
Slider Center Line Thickness
| Number of pixels thick to draw the slider central line
Button Theme Count
| Sets the number of themes available for drawng buttons. Each button theme requires 12 bytes of RAM to store the colour channels.
Theme 0
Foreground
Background
Highlight
| Highlight colour of the theme
Lowlight
| Lowlight colour of the theme
Theme 1
Foreground
Background
Highlight
Lowlight
