| Author
Matrix Ltd
| Version
2.1
| Category
Mechatronics
Servo Motor Controller component
Can control up to eight standard PWM driven servo's.  Supports 8-bit and 16-bit movement resolutions. 'Servo Object' properties allow you to connect the controller to on-screen simulations using the "Servo Motor" component and its derivatives.
Example showing how to control three servos using AutoMoveToPosion, MoveTopposition & SetPosition component macros.
Controlling Servos Example.fcfx
Example using BL0162 Servo controller for BL0055 Arduino Shield
Samples the Port D8-D13 (portB) switches and moves the servo motors based on the input states.
D8 increments motor 0, D9 decrements motor on channel 0.
D10 increments motor 1, D11 decrements motor on channel 1.
D12 increments motor 3, D13 decrements motor on channel 2.
Connections:
Servo Board Port D0-D2.
Switch Board Port D8 - D13
LCD A0 to A5 (PortC)
AutoMoveToAngle
AutoMoveToAngle
| Automatically moves towards the new angle at a fixed rate determined by the AutoMoveSpeed. AutoMove not currently supported by ESP32.
  - BYTE
| The channel to assign the new position. Range: 0-7
  - BYTE
Angle
| Angle in degrees, Range 0 to calibration angle
AutoMoveToPosition
AutoMoveToPosition
| Automatically moves towards the new position at a fixed rate determined by the AutoMoveSpeed. AutoMove not currently supported by ESP32.
  - BYTE
  - BYTE
Position
| Position to automatically move to. Range: 0-255
AutoMoveToPositionInt
| Automatically moves towards the new 16-bit position at a fixed rate determined by the AutoMoveSpeed. AutoMove not currently supported by ESP32.
  - BYTE
  - UINT
Position
| Position to automatically move to. Range: 0-65535
DisableServo
DisableServo
| Disables a servo channel effectivly disabling the motor.
  - BYTE
| The channel to set the position for.  First channel is zero.
EnableServo
EnableServo
| Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
  - BYTE
| Sets up the servo motor interrupts
IsAutoMoving
IsAutoMoving
| Is the AutoMoveToPosition movement complete.   Returns 1 if the servos are still moving.  Returns 0 if all servo movement is complete.
  - BYTE
IsServoAutoMoving
IsServoAutoMoving
| Is the AutoMoveToPosition movement complete for a specific servo output.  Returns 1 if the servo is still moving.   Returns 0 if the servo movement is complete.
  - BYTE
| Servo Motor Output Range: 0-7
  - BYTE
MoveToAngle
MoveToAngle
| Moves a single step towards the new angle, the rate of movement is determined by how often the move to macro is called.  Returns 1 if the position has been reached.
  - BYTE
  - BYTE
Angle
  - BOOL
MoveToPosition
MoveToPosition
| Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called.  Returns 1 if the position has been reached.
  - BYTE
  - BYTE
Position
| Target position to move towards. Range: 0-255
  - BYTE
MoveToPositionInt
MoveToPositionInt
  - BYTE
  - UINT
Position
| Target position to move towards. Range: 0-65535
  - BYTE
SetAngle
SetAngle
| Moves the motor straight to the specified angle. Uses the angle property to calculate the correct amount to move.
  - BYTE
  - BYTE
Angle
SetAutoMoveSpeed
SetAutoMoveSpeed
| Sets the speed of the auto move to position macro.  Default speed is shown in the Servo_Period_Multiplier property.
  - BYTE
Speed
| 1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
SetAutoMoveSpeedInt
SetAutoMoveSpeedInt
  - UINT
Speed
SetPosition
SetPosition
| Moves directly to the specified position with no interpolation.
  - BYTE
  - BYTE
Position
| Position to jump to. Range: 0-255
SetPositionInt
SetPositionInt
| Moves directly to the specified position with no interpolation. Uses a 16-bit position parameter to add extra precision.
  - BYTE
  - UINT
Position
| Position to jump to. Range: 0-65535
SetTrim
SetTrim
| Allows the level of trim for each servo channel to be adjusted progmatically.
  - BYTE
  - BYTE
Trim
| Legacy: 0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us or Smooth: 0-200
Channels (1 - 8)
| Set the number of servo's that you need to control. Value from 1 to 8.
Resources
Peripherals
| Lists the internal peripherals of the MCU used by the component. When the servo motor is initialised you will not be able to use the listed peripherals for other functionality.
Pulse Width
Minimum (us)
| Shortest pulse width that will be used.
Maximum (us)
| Longest pulse width used for the PWM signals.
Channel 0
| Pin on which to output PWM for the servo motor.
Angle
Angle 0
| Range of movement in the servo motor to calibrate the Angle component macros. Can be found by measuring the angle between position 0 and position 255.
Trim
Trim Mode
Trim 0
| Trim the pulse width for this channel.  Use this to trim the positioning of two servos so that similar input values will produce the same degree of movement.
Servo Object 0
| Drag a servo motor component onto the System Panel, and then select it here, to create an on screen simulation of the way that your flowchart moves the servo's. Servo motors should be based on the 'Servo Motor Base' component, or use a custom component set to responf to 'User.Notify' events (ID = n/a,  Data = Position (0-127)).
Please click here to download the component source project: FC_Comp_Source_Servo_Controller.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Servo_Controller.fcfx
