Mathematical Functions
Revision as of 11:05, 3 November 2025 by MartinW (talk | contribs) (Old Versions)
Old Versions
This page is current for Flowcode v11 and later. Earlier versions can be found below:
Flowcode v10
Flowcode v9
Flowcode v8
Introduction
See Calculation Icon Properties
As well as the basic mathematical operators (+, -, *, /), the following mathematical functions can be used in calculations. All of these functions are now usable on each chip type.
Functions
Flowcode includes an additional set of mathematical functions:
Function Prototype Description Example
Floating Point Arithmetic
float = fadd(float, float) Add two floating point numbers together fadd(3.14, 2.86) = 6.0
float = fsub(float, float) Subtract two floating point numbers fsub(10.5, 3.2) = 7.3
float = fmul(float, float) Multiply two floating point numbers fmul(4.5, 2.0) = 9.0
float = fdiv(float, float) Divide two floating point numbers fdiv(15.0, 3.0) = 5.0
float = fmod(float, float) MOD function for floating point numbers fmod(7.5, 2.0) = 1.5
byte = isinf(float) Checks to see if the floating point number is infinite isinf(1.0/0.0) = 1
byte = isnan(float) Checks to see if the floating point is not a number isnan(0.0/0.0) = 1
byte = float_eq(float, float) Compares two floating point numbers to see if they are equal float_eq(3.14, 3.14) = 1
byte = float_ge(float, float) Compares two floating point numbers to see if they are greater then or equal    float_ge(5.0, 3.0) = 1
byte = float_gt(float, float) Compares two floating point numbers to see if they are greater then float_gt(5.0, 3.0) = 1
byte = float_le(float, float) Compares two floating point numbers to see if they are less then or equal float_le(3.0, 5.0) = 1
byte = float_lt(float, float) Compares two floating point numbers to see if they are less then float_lt(3.0, 5.0) = 1
int = random() Generates a random number (0-65535) (random() MOD 10) + 1 = 7 (range 1-10)
fabs( x ), floor( x ), ceil( x ) Absolute value, floor and ceiling functions fabs(-5.7) = 5.7
floor(4.9) = 4
ceil(4.1) = 5
fmod( x , y ) Floating point modulus (remainder of x divided by y) fmod(25.5, 7.0) = 4.5
sqrt( x ), cbrt( x ) Square and cube roots sqrt(25) = 5.0
cbrt(27) = 3.0
log( x ), log10( x ) Logarithms (base e and base 10) log(2.718) ~ 1.0
log10(100) = 2.0
exp( x ), pow( x , y ) Exponential and power functions (x to the power of y) exp(1) ~ 2.718
pow(2, 8) = 256
sin( x ), cos( x ), tan( x ) Trigonometric functions where x is in radians sin(1.57) ~ 1.0
cos(0) = 1.0
tan(0.785) ~ 1.0
asin( x ), acos( x ), atan( x ) Inverse trigonometric functions where x is in radians asin(0.5) ~ 0.524
acos(0.707) ~ 0.785
atan(1) ~ 0.785
atan2( y , x ) Four-quadrant inverse tangent atan2(1, 1) = 0.785
sinh( x ), cosh( x ), tanh( x ) Hyperbolic functions sinh(1) ~ 1.175
cosh(0) = 1.0
tanh(1) ~ 0.762
isnan( x ), isinf( x ) Tests for not-a-number and infinity isnan(5.0) = 0
isinf(5.0) = 0
round( x ) Decimal rounding (x rounded to the nearest integer) round(3.7) = 4
fround( x , y ) Floating point rounding (x rounded to y decimal places) fround(3.14159, 2) = 3.14
asinh( x ), acosh( x ), atanh( x ) Inverse hyperbolic functions asinh(1) ~ 0.881
acosh(1) = 0
atanh(0.5) ~ 0.549
fact( x ) Factorial (multiply all numbers down to 1) fact(5) = 120 (5×4×3×2×1)
Integer Operations
MOD Returns the remainder after division 17 MOD 5 = 2 (17÷5 = 3 remainder 2)
Bitwise Operations
AND <also &> Bitwise AND operation 0b1100 AND 0b1010 = 0b1000
OR <also |> Bitwise OR operation 0b1100 OR 0b1010 = 0b1110
XOR Bitwise XOR (exclusive OR) operation 0b1100 XOR 0b1010 = 0b0110
NOT <also ~> Bitwise NOT operation NOT 0b1100 = 0b0011
<< Left shift operation (multiply by 2^n) 5 << 2 = 20 (5 × 4)
>> Right shift operation (divide by 2^n) 20 >> 2 = 5 (20 ÷ 4)
Logical Operations (usually used in decision branches)
(also =)
Equal to operation Value1 = 26, Value2 = 26
If Value1 == Value2 then True
If Value1 = Value2 then True
(also <>)
Not equal to operation Value1 = 10, Value2 = 20
If Value1 != Value2 then True
If Value1 <> Value2 then True
&& Logical AND operation Value = 10
If (Value > 2) && (Value < 15) then True
|| Logical OR operation Value = 20
If (Value < 5) || (Value > 15) then True
! Logical NOT operation Flag = 1
If ! Flag then False (inverts the value)
Array Functions
arraydims( array ) Get the number of dimensions in an array arraydims(data[5][3]) = 2
arraysize( array ) Get the total size of an array arraysize(data[5][3]) = 15
Hardware Functions
SetPinNoDDR( PortPin, Output ) Set output pin quickly without changing data direction state. SetPinNoDDR(PORTA.0, 1) = pin high
Input = GetPinNoDDR( PortPin ) Read input pin quickly without changing data direction state. GetPinNoDDR(PORTB.1) = 0 or 1
Type Conversion
float2int( x ) Convert floating point number to integer float2int(5.7) = 5 (truncates)
int2float( x ) Convert integer to floating point number int2float(42) = 42.0
Type Casting Operators (For more information see Typecasting)
STRING Convert numeric value to string type STRING 123 = "123"
FLOAT Convert value to floating point type FLOAT 5 = 5.0
SIGNED Convert value to signed integer type SIGNED -5 = -5 (as signed)
UNSIGNED Convert value to unsigned integer type UNSIGNED -5 = 65531 (as unsigned)
