API Sound.Queue
API contents Queues a sound for playing
HANDLE Sounds
- The handle of the sound object to queue to
ARRAY Data
- The array to play data from
ULONG Offset
- The element in the array to start at
ULONG Elements
- The number of elements to play
- The default value for this parameter is: -1
FLOAT RateMul
- A multiplier to the sounds sample rate
- The default value for this parameter is: 1
- Add to a calculation icon: result = ::Sound.Queue(sounds, _arraydata, offset, elements, ratemul)
