Component: SevenSeg ( Indicator)
Revision as of 10:26, 27 April 2026 by SteveT (talk | contribs) (added the example (was in Bluetooth for some reason))
Author MatrixTSL
Version 1.1
Category Indicator
SevenSeg component
A single 7 segment web component.
Version information
1, 1.0, 20-06-24, ST, Created
2, 1.1, 19-02-26, ST, Set colOn and colOff during Ev_Initialising
Example takes an inpt from a slider and outputs the number to a seven segment display. The display prints Err if the number is out of range.
Web 7 Segment Display Example
SetDigit
SetDigit
Sets the 7seg to display a digit (0-9) with an optional decimal point
- LONG Digit
The digit to display (0-9)
- BOOL ShowDP
Set true to show the decimal point
SetOffColour
SetOffColour
Sets the 'off' colour of the segments
- STRING Colour
A string defining the colour (e.g. "maroon" or "#ff0099")
SetOnColour
SetOnColour
Sets the 'on' colour of the segments
- STRING Colour
SetRawValue
SetRawValue
Sets the raw byte value for the 7seg (0 - 255), allowing each segment to be individually set
- LONG Value
The raw byte value for the display (0-255)
Digit
On colour
Off colour
Background
Back colour
Specifies the fill colour of the shape
Outline size
The outline size in pixels
Outline colour
The outline colour of the shape
Value
Please click here to download the component source project: FC_Comp_Source_WEBEXP_7SEG1.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_7SEG1.fcsx
