Calculation Icon Properties
Revision as of 16:32, 9 June 2026 by SteveT (talk | contribs) (Video)
Calculation icons allow the modification of variables. They can be used to check inputs and to create outputs.
Old Versions
This page is current for Flowcode v11 and later. Earlier versions can be found below:
Flowcode v10
Flowcode v9
Flowcode v8
Display Name
Calculations
One or more lines of calculations can be entered into this box.
All calculations must consist of the name of an existing variable, and equals sign and an expression made up from numbers, variables and the following operators:
Caption text
Operator Description
( ) Parentheses
= == Equal to
<>  != Not equal to
+ - * / Addition, Subtraction, Multiplication, Division
MOD  % Modulus
< <= Less than, Less than or equal to
> >= Greater than, Greater than or equal to
>> << Shift right, Shift left
NOT ~ Bitwise NOT
AND & Bitwise AND
OR | Bitwise OR
XOR ^ Bitwise Exclusive OR
&& Logical AND
|| Logical OR
! Logical NOT
Flowcode generally uses the same basic operators as C, but also has English equivalents such as NOT, OR and MOD as shown in the table above. The other difference is a single '=' or a double '==' can be used to compare two values, whereas C always uses double '=='.
Numeric values can be in decimal (unmarked) or in HEX format (preceded by 0x) or in Binary format (preceded by 0b) e.g. 85 or 0x55 or 0b01010101.
Assuming that the variables have been previously defined, all the following are valid calculation lines.
DELAY = DELAY + 1
DELAY = (MYVAR + 3) * 3
NEXTBIT = LASTBIT >> 2 & MASK
AANDB = PORT_A AND PORT_B
INVX = NOT X
$PORTA = $PORTA + 1
$pin39 = $A2
$pin2 = 1
The $ donates a pin or a port that can now be used within calculations.
If any of the variables don't exist, then Flowcode will ask if you would like to create the missing variable.
Variable and Function Box
This section is used to either select a variable or access a list of the available functions. You can reference ports directly or select from a list of available Global or Local variables. You can also view the list of available functions for mathematical and string functions.
IO Ports
Allows you to drirectly drag a poin or port for assigning a value or wihtin calulations. For example:
$PORTA = 10
$PORTC.2 = 1
$C1 = 1
$PORTA.3 = $PORTB.1
From Flowcode V10 With Arduino that uses different pin references the following can be used:
$pin3 = 1
Globals
Globals will allow you to create and drag global constants or variables into the calculation window.
As the variables are global, they can be seen within any user macro's
Locals
Locals will allow you to create and drag local constants or variables into the calculation window.
As the variables are local, they will only be seen within the user macro it was created in.
Outside the user macro, any local variables get destroyed.
Macros
Allows you to drag any user macro into the calculation icon so they can be accessed from within it.
Components
Allows you to drag a component function to control it within a calculation icon.
For example, if using the 2D potentiometer with a variable called ReadADC, the integer value is required, then with a calculation icon:
ReadADC = Potentiometer1 :: GetInt ()
There might be component functions that require an input parameter, then the parameter/s are entered within the brackets.
For example, required the average value after 100 samples and using a 20-microsecond delay:
ReadADC = Potentiometer1 :: GetAverageInt (100,20)
It is easier to read the potentiometer via Components of the Project Explorer rather than the Calculation icon
fx Built-in Functions
This is where all the Mathematical Functions can be found for dragging on the calculation icon.
f$ Built-in Functions
This is where all the string manipulation functions can be found for dragging on the calculation icon.
Video
The Calculation icon video shows how this icon can be used.
