API Component.Delete
Revision as of 14:08, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Delete
Deletes an existing object, removing it from the panel
- HANDLE Target
The object to delete
- BOOL Return
This deletes a component.
Root components and component definitions may not be deleted. All other components may be deleted.
The components memory may not be freed immediately. The system will queue deleted components and erase the memory when the component is not referenced. Therefore a component may delete itself in its own event macro and safely complete processing.
  • Add to a calculation icon:
    result = ::Component.Delete(target)
