API FCD.GetItemHandle
Revision as of 14:08, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
GetItemHandle
Gets a FCD items handle, suitable for traversal with the Tree API
- HANDLE PathName
An existing handle or the '.' separated path through the FCD to look in
- STRING ItemName
The name of an item in the path to find
- HANDLE Return
This will get a handle suitable for traversal by the Tree API which is a collection of functions suitable for traversing the FCD files.
FCD files are XML files. The PathName must be a list of items, not including the XML root tag of the tags where the XML attribute ItemName is to be located. So to extract a handle to the FLASH memory size Pathname="device.memory" and ItemName="bytes".
If the ItemName is not found in the specified location then a 0 handle is returned.
  • Add to a calculation icon:
    result = ::FCD.GetItemHandle(pathname, "itemname")
