API Console.GetLineBytes
Revision as of 14:11, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
GetLineBytes
Reads a line of bytes from the given console extending the array if needed
- HANDLE ConsoleHandle
A valid console windows handle
- ULONG Line
The zero-based index of the line to read the data from, pass -1 for final line
- BYTE[] Buffer
A buffer to read the data into
- ULONG Offset
An offset into Data of the first byte to write to
- ULONG MaxBytes
The number of bytes to read, -1 for full line
- ULONG Return
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::Console.GetLineBytes(consolehandle, line, _arraybuffer, offset, maxbytes)
