API Component.Property.GetListItem
Revision as of 14:11, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
GetListItem
Gets a single list entry from a property by named index
- HANDLE Handle
The component handle to get the property of
- STRING Property
The textual name of the property
- STRING Index
The text or integer entry of the property
- STRING Return
Gets the text part of a list property identified by its 3-digit Index'.
Note the Index is not the line of the list to extract, but the 3-digit identifier. If multiple lines have the same identifier this will extract the first found.
To find the index from the line, use GetListIndex.
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Component.Property.GetListItem(handle, "property", "index")
