| Author
Matrix TSL
| Version
1.0
| Category
Environmental
Humidity AHT10 component
A high precision I2C based temperature and humidity sensor.
Please click here to download the component source project: FC_Comp_Source_Humidity_AHT10.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_AHT10.fcfx
| Startup I2C bus and initialise the sensor. Returns 1 if the device is replying to commands.
- BOOL
ReadHumidity
ReadHumidity
| Gets the humidity reading from the last sample.
- FLOAT
ReadTemperature
ReadTemperature
| Gets the temperature reading from the last sample.
- FLOAT
Sample
Sample
| Reads the sensor and collects the latest termperature and humidity readings. Returns 1 for a successful sample.
- BOOL
I2C Options
| Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
| Specifies the API component on the panel to interact with to provide comms simulation.
