Component: FCD helper (Matrix Tools)
Category Matrix Tools
FCD helper component
A helper control to query the current Flowcode definition XML file.
GetIntListItem
GetIntListItem
Gets a list item from an integer and a textual name Suitable for writing to a property filter Newline is added
- UINT Index
- STRING Name
- STRING Return
GetPropertyList
GetPropertyList
Gets a filter list suitable for adding to a property Uses the [u]IxName[/u] as the index into the list Uses the [u]Text[/u] as the line to show in list-boxes
- STRING FCDPath
- UINT Index
A zero based index of the path to find
- STRING IxName
- STRING Text
- STRING Return
GetStrListItem
GetStrListItem
Gets a list item from a string index and a textual name Suitable for writing to a property filter Newline is added
- STRING Index
- STRING Name
- STRING Return
Register
Register
Registers a property to update when the FCD changes
- HANDLE Dest
- STRING PropName
- STRING FCDPath
- UINT INdex
- STRING IxAttr
- STRING NameAttr
Please click here to download the component source project: FC_Comp_Source_fcdhelper.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_fcdhelper.fcfx
