Component: Motion ( Data)
| Author | MatrixTSL |
| Category | Data |
Motion component
Component that provides motion data for the mobile device using its internal accelerometer
Version information
Library Version, Component Version, Date, Author, Info 1, 1.0, 24-04-26, ST, Created
Many mobile devices contain an internal accelerometer which can report the acceleration in each of the 3 perpendicular axes - x, y and z.
This component allows access to the data provided by this sensor (if available) and can report the data with/without the contribution of the gravity force at that time.
Graphing the accelerometer output
This example shows the acceleration in the 3 axes on a chart.
The web app created by this example can be viewed here: DeviceMotion Example
Using the Motion component with a callback
The is a similar example to above, but this one uses a callback function to retrieve the acceleration data on a regular basis.
DeviceMotionWithCallback.fcweb
The web app created by this example can be viewed here: DeviceMotionWithCallback Example
GetAcceleration
GetInterval
| GetInterval | |
| Returns the interval at which the data is obtained from the device (in ms) | |
| Begins monitoring of the device's orientation information. Returns true if the device can provide orientation information. | |
| Properties | |
| Use Callback | |
| Set true to use a callback that retrieves regular updates of the device accelerometer | |
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Motion.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Motion.fcsx
