Component: DMA (CAL) (Misc)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Misc
DMA (CAL) component
CAL - Code Abstraction Layer A low level implementation giving direct access to DMA routines.
Please click here to download the component source project: FC_Comp_Source_DMA.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DMA.fcfx
Disable
Disable
Disables the DMA channel.
Enable
Enable
Initialise the DMA channel ready to process data to or from a peripheral. The user must enable the corresponding DMA interrupt after initialising the channel.
ReadBuffer16
ReadBuffer16
- UINT Data
ReadBuffer32
ReadBuffer32
- ULONG Data
ReadBuffer8
ReadBuffer8
- BYTE Data
WriteBuffer16
WriteBuffer16
- UINT Data
WriteBuffer32
WriteBuffer32
- ULONG Data
WriteBuffer8
WriteBuffer8
- BYTE Data
Enabled
Enables or Disables the DMA component from generating code.
DMA Peripheral Channel Each utilised DMA enabled component should use a unique channel number
Ping Pong
Controls the ping pong mode. True - Ping pong enabled, DMA memory double buffered to allow for seamless data sampling False - Ping pong disabled, DMA memory single buffered
Mode
DMA Type
Peripheral
Size
