Component: Injector (GPS NMEA) ()
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category
Injector (GPS NMEA) component
Comms data injector to allow simulation of NMEA style GPS messages
Please click here to download the component source project: FC_Comp_Source_InjectorGPS.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorGPS.fcfx
GPS Example File GPS Example Example should show the Latitude generated by the GPS injector as well as the system time in simulation or UTC time on hardware.
Example data provided by the GPS NMEA injector component
GetConsoleHandle
GetConsoleHandle
- HANDLE Return
InitialiseInjector
InitialiseInjector
- STRING InjectorName
RxByte
RxByte
RxByteCount
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
GPS Injector Settings
Data Period (ms)
Amount of time in milliseconds to wait between each GPS NMEA packet is sent. Default 1000.
Circular Buffer Size
Max number of bytes the receive queue can hold. Default 1000.
GPS Location Settings
Data Valid
Injected GPS data validity
Altitude
Injected GPS Altitude
Course Over Ground
Injected GPS course over ground (COG)
Dilution Of Precision
Injected GPS dilution of precision (DOP)
Ground Speed
Injected GPS ground speed (Knotts)
HDOP
Injected GPS horizontal dilution of precision (HDOP)
Latitude
Injected GPS lattitude
Longitude
Injected GPS longitude
Number Of Satellites
Injected GPS number of active satellites
VDOP
Injected GPS vertical dilution of precision (VDOP)
Time & Date Settings
Data Source
Injected GPS source for UTC time and date
