Component: Switch (BL0145) (E-blocks 2)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 8.8
Category E-blocks 2
Switch component
A set of 8 push switches that can be connected to an E-blocks 2 upstream board via a port connector. Switches are wired in an active high configuration.
Version information
8, 8.0, 02-04-25, MW, ESP32 compile fail. Added .Retun to ReadState function
9, 8.0, 08-05-25, BR, Added autodetect port on Ev_PostInitialise
ReadAll
ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
ReadState
ReadState
Read the state of the switch at the given index.
- BYTE Index
The switch to read the status of.
- BOOL Return
WaitUntilHigh
WaitUntilHigh
Pause the program until the switch at the given index is turned on.
- BYTE Index
Index of the switch to wait for.
WaitUntilLow
WaitUntilLow
- BYTE Index
Input Mode
Choose how your switches are connected. PORT = Single port byte for all switches - pins are allocated in sequence from pin 0 - X Custom = Individual pin by pin connections
Port
Please click here to download the component source project: FC_Comp_Source_EB_Switch_BL0145.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB_Switch_BL0145.fcfx
