Component: SPI (CAL) (Misc)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 21.21
Category Misc
SPI component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Serial Peripheral Interface peripheral.
Version information
15, 2.1, 04-11-24, BR, Added pin caption to the remap port pin selection property
16, 2.2, 04-11-24, BR, Cleaned up pin caption from none remap port pin property
17, 2.2, 04-11-24, BR, Minor change to source to reflect change to I2C
21, 21.0, 28-04-25, MW, Minor change sim only to prevent chars FCD Helper from appearing on the display
GetConsoleHandle
GetConsoleHandle
Returns a handle to the console used by this component
- HANDLE Return
GetList
GetList
returns Named property list
- STRING Name
- STRING Return
GetValue
GetValue
Reads Named property Value.
- STRING Name
- STRING Return
Master_Byte
Master_Byte
Sends and receives a data byte
- BYTE DataOut
Master_Disable_CS
Master_Disable_CS
Outputs a high signal to the chip select pin to deselect the remote slave device.
Master_Enable_CS
Master_Enable_CS
Outputs a low signal to the chip select pin to select the remote slave device.
Master_Init
Master_Init
Initialise the Master
Master_Transaction
Master_Transaction
Sends and receives data bytes via the SPI channel. The Buffer is to contain the data to be sent, and is overwritten by the retuning data from the device. Returns 1 for success, 0 for failure
- BYTE Buffer
- UINT Length
Number of bytes to transfer
Master_Uninit
Master_Uninit
Uninitialise the Master
Prv_TextConsole
Prv_TextConsole
Send text to the SPI console. Exposed as part of the CAL_SPI component to allow none AutoCS pins and other.
- STRING str
- BYTE Colour
0=Default, 1=TX, 2=RX
- BYTE AppendTimestamp
0=Don't Append / 1=Do Append
SetPrescaler
SetPrescaler
Sets the prescaler value for the clock divider chain
- BYTE Prescaler
SetValue
SetValue
Change Named property to new Value.
- STRING Name
- STRING Value
Slave_Init
Slave_Init
Initialise the Slave
Slave_RxByte
Slave_RxByte
Returns the data received from the SPI Master
Slave_TxByte
Slave_TxByte
Sets the data to be transmitted to the SPI master.
- BYTE Data
Slave_Uninit
Slave_Uninit
Uninitialise the Slave
Component Enable
A global flag to enable or disable the SPI component from producing code. Useful for generating components with multiple communications options.
SPI Channel selector
MOSI
MISO
CLK
Use Auto CS
Allow the SPI component to manage the CS pin for us in Master mode. On initialise the CS pin is automatically set high to disable the remote SPI device. Set to No if you want to create a component with multiple CS pins or if you want to manage the CS pin yourself.
CS / SS
CS Polarity
Options
Mode
Configures the mode of the SPI component. Currently only Master mode is supported.
Prescale
Prescale option selector
Clock Phase
Clock Polarity
Sample Point
Data bit read sample point
API
Selects the API Slave to use to send and receive real world SPI data during simulation.
Please click here to download the component source project: FC_Comp_Source_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI.fcfx
