Component: Base2dChart (Development)
Revision as of 14:22, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
Author Steve Tandy
Version 1.1
Category Development
Base2dChart component
A base component for creating 2d charts.
Please click here to download the component source project: FC_Comp_Source_Base2dChart.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Base2dChart.fcfx
AddCatData
AddCatData
Adds a data point (y-value only) to the specified series.
- BYTE Series
Which series to add to (1-8)
- STRING Category
- FLOAT Value
The data point value
AddData
AddData
- BYTE Series
- FLOAT Value
AddDataCXYY1
AddDataCXYY1
Adds a data point to a bubble chart.
- BYTE Series
- STRING Category
- FLOAT Y
Y coordinate
- FLOAT X
X coordinate
- FLOAT Value
The value of the data point
AddDataXY
AddDataXY
Adds a data point (x and y values) to the specified series.
- BYTE Series
- FLOAT xValue
The x coordinate for the data point
- FLOAT yValue
The y coordinate for the data point
AddDataXYY1
AddDataXYY1
Adds a data point for a ternary chart (3 axes) to the specified series.
- BYTE Series
- FLOAT xValue
The value on the first axis
- FLOAT yValue
The value on the second axis
- FLOAT zValue
The value on the third axis
ClearData
ClearData
Removes all datapoints from the chart.
GetData
GetData
Gets a data point from the specified series.
- BYTE Series
- INT Index
The data point index (1 - 32767)
- FLOAT Return
GetDataXY
GetDataXY
Gets a data point from the specified XY reference
- BYTE Series
Which series to read from (1-8)
- INT X
X location of the data (1 - 32767)
- INT Y
Y location of the data (1 - 255)
- FLOAT Return
RefreshChart
RefreshChart
Redraws the chart.
SetMode
SetMode
Select the mode of operation
- BOOL bUseArrays
True if data points are added to a hidden buffer; False if data is drawn directly onto chart.
Data
Categories
Y Values
X Values
Z Values
Title
Style
Stacking
Fill Gradient
Transparency
Data Between Ticks
X-axis
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis (secondary)
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Data Labels
Show
Show Category
Show Value
Show Percentage
Show Series
Angle
Position
Legend
Position
Draw Border
Select Series
Series1
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
