Component: Bitmap (Graphical Manager Primitives)
Category Graphical Manager Primitives
Bitmap component
A bitmap primitive used with the Graphical Manager on the GLCD Layout Editor panel. Requires a bitmap drawer GLCD library to be connected to the GLCD and the Display Manager.
A simple example shows how to use a ASC712 to measure current range of +/- 5A. The component type can be changed within its properties.
ACS712 example
GetID
GetID
Returns the assigned object/widget ID.
ModifyBitmap
ModifyBitmap
Allows the bitmap image to be swapped out
- STRING Filename
Bitmap filename in 8.3 file format
- BOOL Redraw
Allows the bitmap to be redrawn immediatley or later on.
ModifyColour
ModifyColour
Changes the theme index of the selected Object or Widget.
- BYTE Index
0=Transparent, 1=Text
- BYTE R
- BYTE G
- BYTE B
- BOOL Redraw
ModifyPosition
ModifyPosition
Moves an existing object or Widget to absolute coordinates on the screen.
- INT X
- INT Y
- BOOL Relative
0=Absolute Positioning, 1=Relative Positioning
ModifyScale
ModifyScale
Changes the width and height of the selected Object or Widget.
- UINT Width
- UINT Height
SetTextFloat
SetTextFloat
Draws a floating point value with optional units onto an object or Widget location.
- FLOAT Number
- BYTE NumDP
Number of decimal points to display
- STRING Unit
Optional unit string to add after the numeric value. e.g. "g" or "s"
SetTextLabel
SetTextLabel
Draws a string onto an object or Widget location.
- STRING Text
Text string to set as the label
SetTextNumber
SetTextNumber
Draws an integer numerical value with optional units onto an object or Widget location.
- INT Number
- STRING Unit
Unit string to add after the numeric value. e.g. "g" or "s"
Bitmap File
BitmapFile
Refresh Bitmap
Reloads the bitmap image from file. Immediatley defaults back to no once complete.
Scaling
Use Transparancy
When set to yes allows a transparent colour to be assigned.
Touch
Touchable
Determines if the display creator defined area responds to touches Touch is detected by using the DisplayManager::CheckForTouch macro with the X,Y coordinates of a touch
Text
Text
Optional default text to add to the inside of the shape
Font
GLCD font to use
Horizontal Alignment
Horizontal alignment of the text label inside the shape
Vertical Alignment
Vertical alignment of the text label inside the shape
Text Colour
The colour of the text
Please click here to download the component source project: FC_Comp_Source_DC_Bitmap.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DC_Bitmap.fcfx
