| Author
Matrix TSL
| Version
1.1
| Category
Timing
Timer Interrupt component
The timer interrupt can be set to trigger a specifed User macro evey time a set time has elapsed. Time units that can be selected are: Milliseconds, Seconds, Minutes, Hours or Days Maximum milliseconds = 4294967295 Maximum seconds = 4294967. Maximum minutes = 71582, Maximum hours = 1193, Maximum days = 49 Times can be changed on the fly
1, 1.0, 06-03-25, MW, Component created
ChangeTimeDays
ChangeTimeDays
| Change the interrupt time to a new time in days. Maximum days = 49 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- BYTE
Days
| Maximum days = 49
ChangeTimeHours
ChangeTimeHours
| Change the interrupt time to a new time in hours. Maximum hours = 1193 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- UINT
Hours
ChangeTimeMilliseconds
| Change the interrupt time to a new time in milliseconds. Maximum milliseconds = 4294967295 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- ULONG
Milliseconds
ChangeTimeMinutes
ChangeTimeMinutes
| Change the interrupt time to a new time in minutes. Maximum minutes = 71582 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- ULONG
Minutes
ChangeTimeSeconds
ChangeTimeSeconds
| Change the interrupt time to a new time in seconds. Maximum seconds = 4294967 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- ULONG
Seconds
StartTimer
StartTimer
| Start timer interrupt running
StopTimer
StopTimer
| Stop the timer interrupt running. Stopping the simulation, also stops the timer interrupt.
Timer Interrupt
Time Unit
| The unit of time to measure
Time Period
Call Macro
| User macro to be triggered every time the interrupt is triggered.
Please click here to download the component source project: FC_Comp_Source_TimerInterruptPCDev.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerInterruptPCDev.fcsx
