| Author
MatrixTSL
| Version
1.0
| Category
Environmental
Temperature (DS18B20) component
A rugged temperature sensor allowing one or more sensors to be addressed and read. Capable of reading temperatures from -55 to +125 degrees C. Requires a One Wire component to perform the bus operations.
Please click here to download the component source project: FC_Comp_Source_Temperature_DS18B20.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Temperature_DS18B20.fcfx
This example shows how to connect the DS18B20 component to the OneWire component and either select a specific device on the bus or scan through the devices on the bus collecting the temperature readings.
The temperature and serial number is output using a UART connection as is onboard a Arduino or ESP32 device.
Example DS18B20
AddressNextDevice
AddressNextDevice
| Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro.
AddressSpecificDevice
| Starts a temperature conversion on a specific device using a hex string identifier. SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
- STRING
SerialNumber
| 48-bit Serial Number e.g. "32DF4A3C1901"
GetSerialString
GetSerialString
| Gets the Serial String for the current addressed device.
- STRING
GetTemperature
GetTemperature
| Reads the temperature from the last sample on the selected device. The selected device is set using the AddressNext or AddressSpecific macros.
- FLOAT
| Configures each matching sensor on the bus with the specified conversion bits.
SampleAddressedDevice
| Performs a temperature conversion on the current addressed device. Requires one of the Address component macros to be called. The temperature can be read using the ReadTemperature macro.
- BOOL
WaitForCompletion
| 0=Dont Wait, 1=Block and Wait To Complete
SampleAllDevices
SampleAllDevices
| Performs a temperature conversion on all compatible devices. The temperature can be read using the ReadTemperature macro. Brefore calling ReadTemperature you need to use one of the Address macros.
- BOOL
WaitForCompletion
One Wire Component
| Link to the one wire component to host the bus.
Sensor Settings
CRC Checking
| Allows the data to be checked before being returned. Useful if the comunication with the sensor cannot be guarenteed. GetTemperature will return 999.9 if the CRC is not a match.
Alarm High
| The high byte of the alarm range
Alarm Low
| The Low byte of the Alarm range
Conversion Bits
| The number of bits used to perform a temperature sample. Controls the conversion time and the resolution.
Max Conversion Time
| The maximum amount of time in milliseconds it will take for a sample to complete.
Temperature Resolution
| The maximum resolution steps that the temperature can be read in.
Simulate Comms
| No - We use the panel GUI to perform the simulation. Yes - We use OneWire comms via an API to communicate with real hardware.
Panel Simulation
Number Sensors
| Sens the number of sensors we can communicate with during simulation
Serial 0
| Serial number for simulated one wire device
