Component: DDS DAC (AD9834/AD9833) (AD9834/AD9833) (Analog Output)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Analog Output
DDS DAC (AD9834/AD9833) component
Component to drive AD9834 and AD9833 Direct Digital Synthesis (DDS) waveform generator ICs via SPI interface. These devices can generate sine, triangle, and square wave outputs with programmable frequency and phase. Compatible with AD9833 and AD9834 devices.
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
Auto Detect Example
DisableOutput
DisableOutput
Disables the DDS output (puts device in sleep mode).
EnableOutput
EnableOutput
Enables the DDS output.
Initializes the SPI bus and resets the DDS device. Call this once at startup.
Reset
Reset
Resets the DDS device. This clears all registers and stops output.
SetFrequency
SetFrequency
Sets the output frequency in Hz. Frequency range depends on clock frequency (typically 0 Hz to ClockFreq/2).
- ULONG Frequency
Frequency in Hz
- BYTE Register
Frequency register to use: 0 or 1
SetPhase
SetPhase
Sets the phase offset. Phase value range: 0-4095 (0 to 360 degrees).
- UINT Phase
Phase value: 0-4095 (0 to 360 degrees)
- BYTE Register
Phase register to use: 0 or 1
SetWaveform
SetWaveform
Sets the output waveform type: 0=Sine, 1=Triangle, 2=Square
- BYTE WaveformType
Waveform type: 0=Sine, 1=Triangle, 2=Square
Device Type
Selects which DDS device is connected.
Clock Frequency
External clock frequency in Hz. Typical values: 25000000 (25 MHz) for AD9833, 75000000 (75 MHz) for AD9834.
SPI Connections
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_DAC_AD9834_AD9833.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_AD9834_AD9833.fcfx
