Component: Combo (BL0114) (E-blocks 2)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category E-blocks 2
Combo component
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Creates a standard stopwatch with 0.01 second accuracy complete with start/stop/restart functionality.
Displays using the 7-segment displays on the BL0114 Combo
Combo connected to Ports A and B
A4 Start / Stop - A5 Reset
Combo 7-Seg Timer
IO_GetPort
IO_GetPort
Reads the state of a single port
- BYTE Bank
0 = Top Bank of Switches, 1 = Bottom Bank of Switches
IO_GetSwitchState
IO_GetSwitchState
Reads the state of a single switch Returns: 0 = Switch not pressed, 1 = Switch pressed
- BYTE Bank
- BYTE Switch
0 = SW0, 7 = SW7
IO_ReadAnalogAsByte
IO_ReadAnalogAsByte
Reads one of the analogue components as an byte value
- BYTE Channel
0 = Light Sensor, 1 = Potentiometer
IO_ReadAnalogAsInt
IO_ReadAnalogAsInt
Reads one of the analogue components as an Integer value
- BYTE Channel
- INT Return
IO_SetLEDState
IO_SetLEDState
Sets the state of a single LED
- BYTE Bank
0 = Top Bank of LEDs, 1 = Bottom Bank of LEDs
- BYTE LED
0 = LED0, 7 = LED7
- BYTE State
0 = Off, 1 = On
IO_SetPort
IO_SetPort
Sets the state of a single port
- BYTE Bank
- BYTE Value
LCD_Clear
LCD_Clear
LCD_ClearLine
LCD_ClearLine
- BYTE Line
The line to clear, zero being the first (top) line of the display
LCD_Command
LCD_Command
- BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
LCD_Cursor
LCD_Cursor
- BYTE x
Set the cursor position in the X plane, 0 is the left most cell
- BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
LCD_PrintAscii
LCD_PrintAscii
- BYTE character
Holds an ascii value.
LCD_PrintFloat
LCD_PrintFloat
- FLOAT Number
- BYTE DecimalPlaces
LCD_PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
LCD_PrintNumber
LCD_PrintNumber
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
LCD_PrintString
LCD_PrintString
- STRING Text
Enter the text or variable to print to the LCD
LCD_RAMWrite
LCD_RAMWrite
- BYTE Index
Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
LCD_RawSend
LCD_RawSend
Sends data to the LCD display
- BYTE data
The data byte to send to the LCD
- BOOL type
A boolean to indicate command type: true to write data, false to write a command
LCD_RemapCharacter
LCD_RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE SearchCharacter
Character to look for a replace
- BYTE ReplacementCharacter
New character value to use in place of the search character.
LCD_ScrollDisplay
LCD_ScrollDisplay
- BYTE Position
Holds the number of positions to shift the display
- BYTE Direction
0 = left, 1 = right
LCD_Start
LCD_Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Seg_ShowDigit
Seg_ShowDigit
Displays a digit on the 7-seg display
- BYTE Digit
Which of the digits to change (0 - 3)
- BYTE Value
The value to display (0 - 9)
- BYTE DecimalPoint
Decides if the decimal point is lit
Seg_ShowSegments
Seg_ShowSegments
Allows the individual segments of the display to be controlled.
- BYTE Digit
- BYTE Segments
8-bit Binary value to set the segments, bit0 = segA, bit1 = segB...
Connection Type
Bank 0 Connections
Bank 0
Bank 1 Connections
Bank 1
Analog Connections
Light Sensor
Light Sensor ADC channel Connected to Bank 0 pin 0 which is usually analog pin AN0.
Potentiometer
Potentiometer ADC channel Connected to Bank 0 pin 1 which is usually analog pin AN1.
Analog Scope Traces
Controls if traces are automatically added to the data recorder window for the analogue signals on the combo board.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
