Component: ADC16bit ADS111x (Analog Input)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA;"" to "class="mtx-class-propfolder"")
Category Analog Input
ADC16bit ADS111x component
A Precision Low power 16Bit I2C ADC 4 channes device with a Programmable comparator
Simple example file to generate a two column CSV file that can be loaded into Microsoft Excel or LibreOffice Math.
The CSV Read/Write component is for simulation or App Developer.
For an embedded CSV read write see the File component
CSV Component used with App Developer -> File component: CSV Test AD
The component requires linking to a File component to provide access to the file system for simulation and runtime, this could be the File SD, File RPI or File AppDeveloper components.
Sets up the I2C bus ready for communications with the device. Returned value: 0 = Success
SampleSglRaw
SampleSglRaw
Performs a single ADC sample on the selected ADC channel
- BYTE Channel
Range: 0-3
- BYTE Mode
Single-Shot Mode - powers down when conversion has finished. Range 0 to 1. 0 = Continuous, 1 = Single-Shot
- BYTE Gain
GAIN 0 = 6.144V, 1 = 4.096V, 2 = 2.048V, 3 = 1.024V, 4 = 0.512V 5 = +- 0.256V
SampleSglVolts
SampleSglVolts
- BYTE Channel
Range: 0-3
- BYTE Mode
- BYTE Gain
- FLOAT Return
Device Address
ADDR connects either to the GDN, VDD, SDA or SCL to determing the address of the ADC.
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
RDY/ALRT
Configuation
Samples Per Sec
Gain A0
Gain is for simulation only. The hardware ADC gain is set within the function parameter.
Gain A1
Gain A2
Gain A3
Simulate Comms
Allows the communications to be simulated overriding the value on the panel slider controls.
Please click here to download the component source project: FC_Comp_Source_External_ADC16Bit_ADS111x.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_External_ADC16Bit_ADS111x.fcfx
