Component: Audio ( Indicator)
Author MatrixTSL
Category Indicator
Audio component
Web-based audio component
AttachToDevice
AttachToDevice
Requests permission to use a microphone feed.
GetRecording
GetRecording
Returns the recorded data
- STRING Return
HasMedia
HasMedia
The media is currently available
- BOOL Return
IsPlaying
IsPlaying
The media is currently playing
- BOOL Return
JumpBy
JumpBy
Seeks the media to a new position relative to the current position
- FLOAT Offset
The position offset of the media (in seconds)
JumpTo
JumpTo
Sseeks the media to the new time
- FLOAT Position
The position in the media (in seconds)
Load
Load
Loads new media (or resets the current media if the parameter is blank)
- STRING Source
The source URL for the media (use empty string to keep use current media)
Pause
Pause
Pauses the media
Play
Play
Starts or resumes playing the media
StartRecording
StartRecording
Starts recording the media
StopRecording
StopRecording
Stops recording the media
Audio
Source
The URL of the source media
Type
The MIME type of the media (leave blank for auto)
Options
Muted
Set true to mute the audio from the resource
Loop
Set true to automatically seek to the start of the media once it has reached the end
Show Controls
Shows or hides the default set of controls (e.g. pause/resume, volume, seeking)
Autoplay
Automatically begin to play the media as soon as it is available
Callbacks
OnAttached
Send when a microphone feed is attached to this component
Advanced
Custom Attributes
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Audio.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Audio.fcsx
