API Component.Property.GetListItem
Revision as of 23:06, 11 June 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Gets a single list entry from a property by named index
Class hierarchy
Component
Property
GetListItem
HANDLE Handle
The component handle to get the property of
STRING Property
The textual name of the property
STRING Index
The text or integer entry of the property
STRING
Returns the single list entry from a property by named index
Gets the text part of a list property identified by its 3-digit Index'.
Note the Index is not the line of the list to extract, but the 3-digit identifier. If multiple lines have the same identifier this will extract the first found.
To find the index from the line, use GetListIndex.
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Component.Property.GetListItem(handle, "property", "index")
