API Sound.SetRate
Revision as of 16:30, 7 August 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Sets the current sample rate for the sound - this will stop the playing sound
Class hierarchy
Sound
SetRate
HANDLE Sounds
The handle of the sound object to modify
ULONG Rate
The sample rate to set
The base sample is specified in creation through Sound.Create. This call does not alter that rate, but specifies a scale factor for the samples played. Subsequent sounds played through this handle will have their wave-forms transformed using this scale factor as a step. Linear interpolation is used to smooth the waveform.
The conversion factor is calculated as (Original_Rate / Rate), meaning a Rate of zero is illegal and will cause the call to fail.
  • Add to a calculation icon:
    ::Sound.SetRate(sounds, rate)
