API Panel.Position.Math.GetDistance
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Gets the distance between two positions
Class hierarchy
Panel
Position
Math
GetDistance
HANDLE Pos0
Start of line to calculate distance from
HANDLE Pos1
End of line to calculate distance to
HANDLE Relative
Position space to calculate the distance in
FLOAT
Returns the distance between two positions
  • Declare a variable 'result' of type FLOAT
  • Add to a calculation icon:
    result = ::Panel.Position.Math.GetDistance(pos0, pos1, relative)
