API Component.Property.SetValue
<sidebar>API Contents</sidebar>
Sets a components property as a string
HANDLE Handle
- The component handle of the property owner
STRING Property
- The textual name of the property
STRING Value
- The value to update the property text with
This sets the internal value of a property, and compliments GetValue.
Note this call does not set the value the property will evaluate to, but sets the value that will be evaluated.
For example, a port connection property may be set to the string "$PORTA", but this call can not be used to change the value of a port.
When code is generated the value of the property becomes fixed for the generated code corresponding to the last call to SetValue().
- Add to a calculation icon:
::Component.Property.SetValue(handle, "property", "value")
