API Component.Property.GetListIndex
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Gets a single lists index value from a property by line number
Class hierarchy
Component
Property
GetListIndex
HANDLE Handle
The component handle to get the property of
STRING Property
The textual name of the property
ULONG LineIx
The lists line (first is zero) to read the index of
STRING
Returns the single lists index value from a property by line number
Given a Property which is a list type, this gets the index (3-character) part of the line corresponding to LineIx, with zero being the first line. This index can then be used in GetListItem and related calls.
The lines of the property are stored in its filter - see GetFilter.
No checks are performed to establish the property is of the correct type.
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Component.Property.GetListIndex(handle, "property", lineix)
