API Panel.Position.Math.GetDiff
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Gets the difference between two positions
Class hierarchy
Panel
Position
Math
GetDiff
HANDLE Pos
Position to act as the minuend to calculate position from
HANDLE Sub
The position to subrtact from Pos
HANDLE Relative
Position space to calculate the difference in
HANDLE
Returns the difference between two positions
  • Add to a calculation icon:
    result = ::Panel.Position.Math.GetDiff(pos, sub, relative)
