API Expand.VarName
<sidebar>API contents</sidebar> Expands a string to the name of a global variable used in the generated code
STRING Source
- The variable name to expand
HANDLE Owner
- A component that owns the variable
BOOL SizeName
- Set true to return the expanded size define
BOOL FullLine
- Set true to expand to a full declaration, else just the name
The global variable name as it would exist in the generated code
This expands a global variable to the name it would be given in the generated code. The size define (the size of the final dimension of the array) may be returned instead if required.
Note this does not return the full expression unless FullLine is true. In this case, Source must be a valid variable name for the Owner component, as the system needs this in order to expand the variable type, array sizes and initialisers.
- Add to a calculation icon:
result = ::Expand.VarName("source", owner, false, true)
