API Panel.Position.Camera.SetView
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets the eye and target focal point of the camera
Class hierarchy
Panel
Position
Camera
SetView
HANDLE Eye
The position of the eye to set the camera to
FLOAT FocalRange
The distance the target will be from the eye
BOOL Animate
True to animate movement from the current position
This call is the equivalent of calling both the SetEye and SetTarget calls.
The Eye is explicitly defined, and the target is calculated as FocalRange world-space units along the Z axis of the Eye position.
  • Add to a calculation icon:
    ::Panel.Position.Camera.SetView(eye, focalrange, false)
