API Panel.Position.Camera.SetLookAt
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets the eye and target point of the camera
Class hierarchy
Panel
Position
Camera
SetLookAt
HANDLE Eye
The position of the eye to set the camera to
HANDLE Target
The position of the target to set the camera to
BOOL Animate
True to animate movement from the current position
This call is the equivalent of calling both the SetEye and SetTarget calls.
The Eye and Target are used to calculate the camera coordinates. The orientation of the camera is calculated by taking the up-vector of the Eye position and rotating this to look at the target. If the up-vector is parallel to the vector from the eye to target, an orthogonal vector is chosen as up.
  • Add to a calculation icon:
    ::Panel.Position.Camera.SetLookAt(eye, target, false)
