API Panel.Position.ScaleUp
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Multiplies the objects scale by a value
Class hierarchy
Panel
Position
ScaleUp
HANDLE Handle
FLOAT X
The local X scale to multiply by
FLOAT Y
The local Y scale to multiply by
FLOAT Z
The local Z scale to multiply by
This multiplies the scale of the Handle object by an absolute value. Note the difference between scale and size. An objects scale is only equal to its size if it has no child objects to define its boundary.
  • Add to a calculation icon:
    ::Panel.Position.ScaleUp(handle, x, y, z)
