Exercise - Using Analogue Input Devices
Revision as of 19:44, 24 June 2013 by JohnVerrill (talk | contribs)
The aim of this exercise is to use analogue input devices within a Flowcode flowchart.
Digital inputs are simpler to deal with, as they have a finite range of possible values.
For example, a two bit digital input can have one of only four possible values - 00, 01, 10 or 11.
Flowcode uses an 'Input' icon to deal with digital inputs.
An analogue input, on the other hand can have any of an infinite number of possible values.
As a result, it is more difficult to handle in Flowcode. A component macro is used to input data from an analogue sensor.
The first section looks at using 'Component Macros' to create the core timing sequence. The second section looks at using it to turn on a lamp for ten seconds once a switch is pressed.
The core timing sequence
At the core of the program is a section that sets up the LCD to display the time.
The flowchart sequence for displaying the elapsed time will be:
  • Initialize the LCD using the 'Start' macro.
  • Set the cursor position in the LCD, using the 'Cursor' macro.
  • Display the text "Elapsed time", using the 'PrintString' macro.
  • Set the time to zero.
  • Change the cursor position, using the 'Cursor' macro.
  • Display the time.
  • Wait for one second.
  • Increment the time.
  • Display the new time.
Create the 'input' variable
  • In the 'Edit' menu, on the main toolbar, click on 'Variables...' to open the Variable Manager dialogue box.
  • Hover just to the left of the 'Variables' label, and click on the down arrow that appears.
  • Select 'Add new' and the 'Create a New Variable' dialogue box opens.
  • Name the new variable "input".
  • Leave the variable type as 'Byte'.
  • Click on 'OK'.
  • The dialogue box is shown below.
  • Click and drag an infinite loop between the 'BEGIN' and 'END' icons.
  • Inside the loop:
  • Click and drag a 'Component macro' icon.
  • Double click on it to open the dialogue box, so that you can configure it.
The program 'knows' which components you have added to the System or Dashboard panel, and modifies the list of available commands accordingly.
Under 'Components', the ADC dial will be listed, and underneath it the list of commands.
  • Scroll down the list and click on the 'GetByte' command.
This reads the output of the analogue input device - the ADC dial in this case, and stores it in the byte variable 'input'.
  • Rename the 'Display name' as "Read the input".
  • Click on 'OK'.
  • Next, drag and drop a 'Decision' box, and double click on it to open the dialogue box.
  • Rename it "Switch pressed?".
  • In the condition 'If' box, type "switch=1"
  • Click on 'OK'.
  • In the 'No' branch, drag and drop a 'Connection Point (Jump to Connection Point)' icon.
  • In the 'Yes' branch, drag and drop an 'Output' icon.
  • Double click on it to open the dialogue box.
  • Change the 'Display name:' to "Switch on the lamp".
  • In the 'Variable or value:' box, type "1".
  • Configure the rest of the box to output this to 'PORT A' 'Single Bit:' 0.
  • Click on 'OK'.
Add the LED
  • Locate the 'Single LED' in the 'Outputs' toolbox in the Icons toolbar.
  • Hover over the image to the left of the 'Single LED' label, and click on the down-arrow that appears.
  • Click on the 'Add to system panel' option to select it.
  • Select the LED on the System panel and drag it to a suitable position.
  • Look at the Panel Properties, the 'Connection' property shows that, by default, it is connected to Port A, bit 0.
Leave it like this.
