API Panel.PCloud.SetPointsEx
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets the X,Y,Z point lists
Class hierarchy
Panel
PCloud
SetPointsEx
HANDLE PCloud
The handle to the cloud set the points of
FLOAT[] X
The array of X coordinates to use
FLOAT[] Y
The array of Y coordinates to use
FLOAT[] Z
The array of Z coordinates to use
ULONG OffsetInfo
The offset and step to increment each axis in
ULONG Elements
The number of (X,Y,Z) points to set
  • Add to a calculation icon:
    ::Panel.PCloud.SetPointsEx(pcloud, _arrayx, _arrayy, _arrayz, offsetinfo, elements)
