API Panel.LinkBar.SetEndGfx
Revision as of 13:39, 1 July 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Sets the graphic for the end point of the bar
Class hierarchy
Panel
LinkBar
SetEndGfx
HANDLE LinkBar
The handle to the bar to alter
ULONG Mode
The graphics mode to draw the bar end-point with
Typical values for this parameter:
Name Description
Cap_None No cap is drawn for the start or end point
Cap_Line A line arrow is drawn
Cap_Triangle A flat 2D traingle
Cap_Cone A 3D cone
Cap_Sphere A 3D sphere
Cap_Dome A 3D half-sphere
Cap_Cylinder A 3D cylinder
ULONG RGBA
The red, green, blue value to colour the point with
FLOAT Width
The width to use for 3D and arrow modes
FLOAT Height
The height to use for 3D and arrow modes
This sets the graphics mode for the end point of the bar. The default for the end is to have no graphics.
The Mode is the type of link to draw, and if a graphic is to be drawn this will be affected by Width and Height. Width is always assumed to be positive and its sign is ignored, but Height may be negative to invert the arrow or graphic specified.
The RGBA is a true-colour red, green, blue value. This is 255 (0xFF) for red, 0xFF00 for green and 0xFF0000 for blue.
  • Add to a calculation icon:
    ::Panel.LinkBar.SetEndGfx(linkbar, ::Panel.LinkBar.Cap_None, rgba, width, height)
