Common Components
<sidebar>Sidebar: Controlling Electronic Devices With Flowcode</sidebar> Components commonly used in Flowcode, such as; Switches, LEDs, LCDs, 7 Segment Displays and Keypads all have a good range of components for suitable use in different fields and systems as well as strong base components to expand and create your own components for specific systems or for use across different systems and platforms.
The simplest type of component is a Switch component is used as a trigger to send a command in a program, e.g. an on or off switch to initialize and disable or stop a program, process or system. Switch components come in two types; 'latching' such as an on/off switch or toggle switches, and 'momentary' such as a push button switch or a push-to-make switch.
Light-emitting diode (LED) components are also commonly used and are often matched / coupled with switch components to indicate if an element is powered on or functioning correctly. LEDs are mostly used as indicators in common applications and systems such as traffic lights and car indicators which are visual ques and indications to convey direction and processes.
Furthermore liquid-crystal display (LCD) components are used in a similar way to indicate processes albeit more clearly, displaying information such as the function or process of a DVD player e.g. opening and closing the disc tray, reading the disc, changing volume etc. or displaying ongoing information such as the time and date and other information such as news or current information.
The seven-segment display (SSD) displays are also used to convey information albeit less complex then the LCD, this component can clearly and simply display numbers with ease. It has great compatibility within Flowcode as it is controlled simply by inputting the digit to be displayed and a digit to enable/show or disable/hide the decimal point on the display. The component also works with variables instead of simply the digit, this allows other components to manipulate this variable to change the digit to be displayed by the 7 Segment Display.
Finally, the Keypad component is the most effective component for inputting data such as variables in order to manipulate and operate other components interactively using variables to transfer the data. The Keypad Base component has a basic set of numbers (0-9) as well as A and B digits, if programmed correctly a keypad component can write alphabetical letters, numerical digits as well as ASCII symbols which can then be used to transfer the data for a different component to display.
