API Sound.LoadWav
<sidebar>API Contents</sidebar>
Loads a wave file into memory, providing the values needed to play it
STRING Filename
- The formatted file to load into memory
BYTE[] Buffer
- A buffer to write the wave data to
UINT SampleFormat
- Variable to receive the format of the samples
- This parameter is returned back to the caller
ULONG Elements
- Variable to receive the number of sample elements to play
FLOAT SampleRate
- Variable to receive the wave source sample rate
Returns true if the operation is a success, else false
This loads WAV files given a Filename to the data. The Filename may point to a resource file. The data in the file should be in a RIFF format, see WAV file for a more detailed description of a WAV file.
On exit from the routine, the Buffer, SampleFormat, Elements and SampleRate are all updated to contain data read from the file. These are all written with zero values (Buffer is not altered) if the call fails.
If Buffer is not large enough for the wave data it is resized in the call to an appropriate size.
- Add to a calculation icon:
result = ::Sound.LoadWav("filename", _arraybuffer, return_sampleformat, return_elements, return_samplerate)
