API Language.Translate
Revision as of 20:28, 8 August 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Takes English text and optional hint and converts to the current language
Class hierarchy
Language
Translate
STRING Text
The English text to translate to the Flowcode language
STRING Hint
A contextual single word hint to help the translation
The default value for this parameter is: ""
STRING
The converted string in UTF8 format for the selected Flowcode language pack. Text if no conversion exists.
This takes the English string Text and attempts a conversion to an equivalent phrase in the users native language. The dictionary searches are exact (minus punctuation and case) - there is no predictive or fuzzy logic applied in order to translate. This means results stay fast and accurate.
If the English phrase is not found in the dictionary then it will be returned as the result.
The Hint is used in cases where an English phrase is ambiguous - "Bark" for example may refer to bark of a tree or the sound a dog makes. In this case supplying the Hint as "dog" or "tree" helps resolve ambiguity. Hints are not case sensitive and by convention are always one word. Not all phrases have a hint 9most will not) as these are only required where a phrase can have different English meanings.
By convention Flowcode uses Americanised English, so "color" not "colour".
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Language.Translate("text", "hint")
