API Panel.Position.GetBox
<sidebar>API Contents</sidebar> Gets a handle to an object representing the components bounding box position
HANDLE Handle
- The position or component to read from
Returns the handle to an object representing the components bounding box position
This call gets the objects bounding box position. This can be thought of as the objects size rather than its raw scale value.
The difference between scale and size only applies to objects with child objects, such as groups or compiled components.
- Add to a calculation icon:
result = ::Panel.Position.GetBox(handle)
