Finding Your Way Around Flowcode
Revision as of 12:06, 13 August 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: Getting Started</sidebar> Before getting started it is recommended to first of all familiarize yourself with the interface of Flowcode.
If you feel a bit overwhelmed by the interface you can close the panels and views by clicking on the cross button to the top right of the window, panel or view, you can also enable and disable the panel or view using the 'View' menu.
In the following articles you can learn how to operate Flowcode on a basic level, there is also an introduction of some of the main features to help you understand Flowcode.
Don't worry if you do not understand it all at first, the features will be detailed in greater depth in other articles. If you are unsure of any element there should be hyperlinks which will take you to a detailed page describing and explaining the element.
