API Panel.Position.RotateY
Revision as of 15:34, 10 May 2013 by Admin (talk | contribs) (XML import API auto-gen)
<sidebar>API contents</sidebar> Rotates the object around the Y axis
HANDLE Handle
HANDLE PivotHandle
An optional position to treat as the origin to rotate around
FLOAT Degrees
Number of degrees to rotate by
  • Add to a calculation icon: ::Panel.Position.RotateY(handle, pivothandle, degrees)
