One second LED flasher
If Flowcode is mis-configured for your hardware then time dependent code such as delays, communication bauds, timers etc. will fail to run as intended. A very simple way of confirming your hardware is configured correctly in Flowcode is with the use of a one second flasher program.
The one second flasher program simply consists of a loop, a couple of delays and a couple of output icons. The idea is to switch an output pin on and off to which a LED and series resistor (200R - 1K) can be attached to confirm if the delays are approximately equal to a second. The likelihood is that the delays will be either bang on one second or will be way out confirming there is a configuration issue.
Here is a example of a one second flasher program.
If the delays on the hardware do not equal one second or the LED does not flash at all then here are some areas to check.
Is the Project Options project clock speed setup correctly for your oscillator source? This value can be selected from the drop down list or typed in directly to allow for any oscillator speed.
Is the Project Options configuration setup correctly for your oscillator source? These settings will vary from device to device so it is often necessary to refer to the device datasheet for details on specifics.
Generally speaking a crystal oscillator below 4MHz is the XT option, above 4MHz is the HS option also the Watchdog timer, Low Voltage Programming and Extended CPU settings should be disabled.
