API Component.Property.GetListIndex
<sidebar>API Contents</sidebar>
Gets a single lists index value from a property by line number
HANDLE Handle
- The component handle to get the property of
STRING Property
- The textual name of the property
ULONG LineIx
- The lists line (first is zero) to read the index of
Returns the single lists index value from a property by line number
Given a Property which is a list type, this gets the index (3-character) part of the line corresponding to LineIx, with zero being the first line. This index can then be used in GetListItem and related calls.
The lines of the property are stored in its filter - see GetFilter.
No checks are performed to establish the property is of the correct type.
- Add to a calculation icon:
result = ::Component.Property.GetListIndex(handle, "property", lineix)
