API System.ShowHandle
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Given a handle to an object with viewable presence, shows that object on screen
Class hierarchy
System
ShowHandle
HANDLE Handle
The object to display on screen
BOOL
Returns true if the operation is a success, else false
This tells Flowcode to show whatever object is represented by Handle.
The types of object that are supported are:
Handle type Result of this call
Component Moves the camera in its current viewing plane over the components position
If the panel (system or dashboard) the component exists on is not shown, this will open that window
Position Behaves as though a component, and moves the camera to look at that position
LinkBar Behaves as though a component, and moves the camera to look at the center of the link
Point cloud Behaves as though a component, and moves the camera to look at the center of the cloud
Console Opens the console window and selects the appropriate console tab
Scope group/stream Opens the data scope window to show the scope
  • Add to a calculation icon:
    result = ::System.ShowHandle(handle)
